Are there different quality kits available? LIke China vs.India or is there a preferred source for the kit that has better quality or price?
I'm looking at the ones that cost about $140 and come with
GASKETS
SAFETY VALVE
CONTROL VALVE
CHAMBER REPAIR KITS
CAM BLOCKS
PISTONS
BUSHING
http://cgi.ebay.com/8N-9N-2N-TE20-TO20-T030-HYDRAULIC-PUMP-REPAIR-KIT-/160523937137?pt=LH_DefaultDomain_0&hash=item255ff8e571#ht_500wt_1156
I haven't pulled the cover yet to do any diagnostics because I'm in the process of rebuilding the starter. Over the summer the hydraulics got weaker and weaker. By the end of summer I had to run at high throttle to keep the mower off the ground. Lotsa leakdown.
I don't mind putting $150 into the repair kit. Is there anything else I need to "do it right" while I'm inside there replacing things. I have the shop manual I got at Tractor Supply Co.
Should I pull the pump and look at the piston and rings?
heres a kit I was looking at
