8n Hydraulics
HoraceTOK
i have gotten my 8n going but i found out the hydraulics dont work. do you think it is the pump or the fluid or other problems? any awnser would help!!! Thanks:)
Check the fluid. (tip # 3)
Is the PTO engaged?
It won't lift if you push the clutch in; the 8N doesn't have live hydraulics.
Is it in position control or draft control? (tip # 58)
Post back w/ results & we'll go from there.
75 Tips
As Bruce said, most common cause would be PTO turned off
or the clutch depressed. They just weren't made that way.
Does your 8N have and auxiliary transmission?
If so, it may also need to be engaged.
