I have mild drift down. So I was thinking of going after the piston. I have a few questions.
1) 8N JIG AND BOOKLET FOR ADJUSTING THE 8N LIFT
Is this a must for the job?
2) I am thinking a NNA piston, and rings? Any reason not to?
3) How often is the piston sleeve to bad to be homed out? Should I mail order a new sleeve with the new piston and rings.
4) Is a whole pump rebuild a must?
5) If no on the pump rebuild. I assume it is best to pull it and clean off the gunk? If so should I replace an parts just cuz? Relief valve?
Thoughts?
Earl
Thoughts?
Earl
