8n hydrulic pump cover remover
Im trying to remove the pump cover on the bottom.
I have all the bolts out and it still acts like theres something holding it up.It dropped down about an 1/8 of an inch and hangs up.Is there something Im missing. I dont want to force it and break something if so.
again thanks for all the help in the past.
didja remember to pull the pto shaft out? it goes thru the pump.
onc ethe pto shaft is out, the pump front will drop a bit and then you should be able to wiggle it out a bit.. might not want to come 100% straight down.. but just a lil down angle on the fornt side.
post back.
soundguy
