fostersfarm
Recently rebuilt hydraulic lift. [new cylinder, naa piston,etc.]
1. With use had “chatter”, [noise and movement]
2. Raised and lowered ok and stayed up 48 hours.
3. Used half a day with light weight scarper and now with medium weight disc have a knocking sound, one knock per pto shaft revolution. Pump?
4. Now must pull lift lever to top to raise 3pt.
5. No chatter or knock before rebuild but tractor has been setting for a year.
6. Oil level between marks on dipstick. Stick says to fill with cylinders extended [lift arms?]. Will fill to bottom bolt hole tomorrow.
7. No wobble at end of pto shaft. No leaking.
8. I have the original pump for this tractor that was exchanged because lift would not stay up.
When installing lift cover had to pull lift control arm about 3/16 inch to right side to guide it into the intake control valve.
Thanks, Foster
Thanks, Foster
