SteveRusssell
The tractor is a 1952 8N after sr#216xxx, side mount distributor, 4 speed. 6volt, positive grnd.
Situation: The lift would no longer "lift" an implement. It would until recently, but always leak down quickly , if motor was shut off. Couple months ago I did the Quick fix of changing the fluid and Washing out the houseing with Diesel. NO change. Whis past week I drained it again, took off the side plates and also changed out the piston in the cylinder to the NAA530b with the O-Ring and leather back up, did hone the cylinder, but it was not in bad shape. Washed and blew it out and installed new fluid. The lift arms would go up very quickly but would not go down until I adjusted the area of the quadrant. I did not take the pump out, I had the bolts out and tried to drive it out with a 2x4 like the boys on the DVD did, but it was so tight I was afraid of breaking it.
It will now lift the implement quickly,& hold it with motor running, only, or drifts down quickly, when motor is turned off.. What would be your suggestion to get this working correctly? Is there an adjustment yet, or get a bigger hammer to get the pump out and rebuild it. The tractor is 150 miles away, so can't run outside to double check anything now.
Thank you.
Thank you.
