I am working on a 49 8N and I need a new Long pin that goes on top of the differential. I can't find a part number in the manual or on any of the parts suppliers I have looked at. Anyone have a part number and/or know if new replacements are available?
(quoted from post at 01:21:27 01/09/13) OEM or reproductions not available.
Good used ones difficult to find.
Dean
(quoted from post at 08:39:18 01/09/13) It is available at external_link
Years: 1948-52
Category I Top Link Pin, 3/4 Pin Diameter, 9-3/4 Useable Length, 10-5/16 Overall Length. Hinged Pin.( Used With 8N 4110 Bushing )
http://www.external_link/catalog/product_info.php?products_id=443
Untitled URL Link
(quoted from post at 11:38:34 01/09/13) The 8N486A Ford pin was one solid piece. The Ferguson pin was hinged in the middle. The Ferguson pin has the same dimensions and will work on your Ford. Reproductions of the Ferguson pin are readily available from aftermarket dealers. Here's a picture of the two.
Smiths
(quoted from post at 17:39:45 01/09/13)(quoted from post at 11:38:34 01/09/13) The 8N486A Ford pin was one solid piece. The Ferguson pin was hinged in the middle. The Ferguson pin has the same dimensions and will work on your Ford. Reproductions of the Ferguson pin are readily available from aftermarket dealers. Here's a picture of the two.
Smiths
OK - I'll bite. What makes the Ford one piece pin special? How is it different (aside from hardening or heat treating) from any other solid pin that length?
TOH
(quoted from post at 11:18:16 01/09/13) DScott........the LONG pin was for the jingle-jangle support bars that kept the 11-hole drawbar at a constant height for towing 'specially fer backin'up. Unless you LOCK yer hy-trol handle, yer hydraulics will BEND yer support bars iff'n you try to lift it.
Remember for towing with the 11-hole drawbar, you haffta provide anti-roll devices 'cuz the leverage of the roundball trailer hitch will make'r turn-over.
Me? I like the under the diffy cranked tow bar with the turn UP so it smacks yer kneesies 'stedda yer ankle. The reason fer the "hinge" on the Ferguson long pin is so you can install it with the fenders ON.
BTW, the LONG pin was "optional", and necessary for very few applications. Use the SHORT pin with yer telescoping top-link. Do NOT use the upper top-link attach hole. It will "kill" yer hydraulic linkages. ........Dell
(quoted from post at 12:13:15 01/09/13)
That's a bracket for a rear mount Dearborn sickle bar mower.
