[email protected]
I looked at a previous discussion on replacing the lower link pin, but nothing was mentioned about the cover plate. Mine has a cover plate at this location. My link pin in loose and spinning, but so is the bolt that apparently holds the cover on. The cover is also loose and leaking. The confusing thing to me is that the bolt won't come out or tighten, just spins freely. I'm guessing that it must also have a nut inside the housing like the lower pin? It seems like it should hold the cover plate on without the need of a nut inside so that you could remove it without taking the axles and the third member out. So I guess the question is do I need to take everything apart just like the ones that don't have the cover plate?
Thank you, Troy
Thank you, Troy
