CircleN
I have 1947 8N converted to 12 volt.
between the coil and right above the distributor there is a black box which I am being told is a Magneto that needs to be replaced.
I can not find this part to order, is this something that is only available in a conversion kit, or is it called something else that I can
order.
please help
(quoted from post at 12:49:49 04/14/20) I have 1947 8N converted to 12 volt.
order.
please help
Does your tractor have a round can like coil on it? If so, what you are describing is the shell of the OEM coil. Was the tractor running and now isn't? A little background will help.
I think you are referring to the square coil that sits on top of the front mount distributor. Go to any online tractor parts site. Do a search for " Ford front mount coil" I think you will find your "black box"
Power to coil none to distributor
Yes has a round cylinder coil
Engine turns over spark leavening coil but no spark at distributor
Turned engine off but would not start after words
(quoted from post at 20:57:25 04/14/20)
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto1538.jpg">
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto1539.jpg">
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto1540.jpg">
No magneto - you have a front mounted distributor. Someone has gutted the OEM square coil and wired a round coil into it.
TOH
A good cleaning would help, electricity don't like dirty parts.
If you are getting a spark out of coil, replacing it will not change anything. look at rotor in distributor. Also if you are getting a spark out of the coil the points are doing there job!
Agreed with the others -you don't have a magneto, you have the front mount distributor. I can rebuild yours or exchange as I'm sitting on three OEM rebuilds now all set to go. My Email open. Decide which electrical system you wish to use. Invest in the Essential Manuals while you wait.
CORRECT FORD 8N ELECTRICAL SYSTEMS - 6V & 12V:
FRONT MT 12V:
*PICTOGRAMS courtesy of JMOR
FORD 8N TRACTOR ESSENTIAL OWNER/OPERATOR/PARTS/SERVICE MANUALS:
Tim Daley(MI)
"Yes has a round cylinder coil Engine turns over spark leavening coil but no spark at distributor" From that, it sounds like your coil wire went open. How are you testing the "no spark at distributor"?
