.............and from yesterday, "(quoted from post at 11:38:24 03/21/14) I am using an old plug as I don't have a checker. There is no spark at 1/4 inch specified. I have no way for me to check the voltage across the points because the only thing I have is a test light. Is there any other way I can check them?
K, since you had the cap on without the bump/slot alignment (wobbled), then it is time to examine condition of rotor & cap, looking for damage where the rotor may have come into contact with a cap post.(quoted from post at 12:20:07 03/21/14) No spark at the plugs but there is at the
primary wire
ot a lot of possibilities between wire between coil & center of distributor cap and the plugs.......cap, rotor, 4 plug wires. That is only 6 items to verify. Get after it.(quoted from post at 12:35:22 03/21/14) Both look to be fine. No scoring or burnt
areas
(quoted from post at 13:10:12 03/21/14) The wire leading from the coil to the side of the distributor has spark. However there is nothing coming through the cap. I pulled the sparkie wires off and hooked each of them into the top of the coil and connected a test light to the end. All had spark. When I put them back onto the cap, they have no spark.
K. Take distributor cap off for access to points. Bump starter until points are open. Turn on key & use screwdriver to short across open point gap. Look carefully for a spark at screwdriver......it will be quite small compared to secondary spark. During this time did coil still get hot?(quoted from post at 15:59:38 03/21/14) I have notice that even for the short
amount of time I had the key on testing
for spark, the coil is scalding hot.
id the coil get hot this time? See if the high voltage tower produces a spark when the screwdriver produces a spark.(quoted from post at 17:49:48 03/21/14) There was a spark although it only happened about 50% of the time, meaning sometimes there was a spark, sometimes there wasn't. I never did get a spark between the contact points themselves, only from the metal strips they are attached to.
(quoted from post at 00:34:48 03/22/14) " There was a spark although it only happened about 50% of the time, meaning sometimes there was a spark, sometimes there wasn't"
There two possibilities why that is occurring, both of which I've already addressed:
" First, charge the battery. (see tip # 60) . A weak battery gets you a weak spark. Or no spark."
" So 'wiggle' the insulator & the copper strip a bit when you are doing your checking. "
So, have you charged the battery? Have you checked the insulator & copper strip for a short?
And, does your test light come on across the open points?
K, if the coil still got hot with points open, then the possibilities are the copper strip/insulator bushing that Bruce described or a shorted condenser. Easy to disconnect condenser & see if heating persists. Then disconnect the wire from coil to distributor feed-thru & surely heating will stop. Don't despair....we are nearly there.(quoted from post at 22:00:22 03/21/14)(quoted from post at 00:34:48 03/22/14) " There was a spark although it only happened about 50% of the time, meaning sometimes there was a spark, sometimes there wasn't"
Yes the coil got hot. The battery is charged. I have no way to test for a short in the strip or insulator as I only have a test light. The test light does not come on when in contact with the points.
f that is all you did (not inadvertently move/remove some other unknown connection), then it sounds like you have a shorted condenser.(quoted from post at 18:00:24 03/22/14) When I disconnected the condenser the coil
did not get hot.
