I have a 51 8n sidemount Dis. 12v con.
that is letting water come out from under Bat. caps and run down the side of the tractor looks like white powder,y stuff .. also when i volt meter the Bat. i,m only charging 12.3 to 12.5 volts with tractor running . I get the same thing on the one wire pole on the back of the ALT. (12v Con) & my amp meter on the dash is on 0 and quvering.. This tractor should be charging 13 to 14 volts right? Oh Amp meter is new and been working fine.. Is my ALT. going out? should it not have more then 12 volt on the pole on back when it is started up & spinning ?
Thanks Jeff (TN)
Thanks Jeff (TN)
