TexasCowboy
I have owned this 8n for 17 years. I runs sometimes, or it
doesn't.
A 4 cylinder engine should not be this hard to keep running. I
rebuilt my first engine, a 1959 Ford Escort, when I was 17. It
started first time and ran fine for the rest of the time I owned
it.
I bought this for for sentimental reasons. I learned to drive a
tractor on a 1953 Ford 8n when I was 4 years old.
Now, no spark. Most of the ignition components are new. I am
thinking, if I can't get it running again tomorrow, I will borrow
my neighbors John Deere and send this stupid Ford to the scrap
yard and buy a new JD. This tractor has always been hard to start
but pulling it always worked. Not anymore. Since I rebuilt he
engine it has compression high enough that the tires won't turn
unless it is in 3rd gear. Still won't even fire. Plugs, wires,
coil, points, condenser,rotor, cover, ignition switch, wiring
harness. All new, and still won't produce a spark. A suggestion
from a 8n owner would help but don't tell me I don't know what I
am talking about because I know more about enine mechanics that
almost anyone here. This stupid Ford just doesn't follow he rules.
Air fuel, spark. That is all it takes. I have air. I have fuel.
I don't have spark, and I can find no mechanical or elecrical
reason why.
I should add. Tractor was starting and running fine. Hooked up
to the shredder and pulled it into the barn to hook it up to the
hoist so I could remove the blades to sharpen them.
Turned it off while was working on the shredder. Hasn't started
since.
doesn't.
it.
reason why.
since.
