Well, my 8N (about a 1951 model, SM distributor) all of a sudden has no throttle response. It will start, but barely runs, and does not increase speed when throttle is advanced. Yes, I checked all the linkages and fuel flow to the carb, and they are apparently normal.
I checked compression, and all cylinders are 90-95psi. My thought is that this indicates valves are closing okay, and no head gasket leak (no water in oil, oil is clean and normal level).
It almost acts as though it may be out of time, but it starts, and there's no back-firing.
Could it be a cam gear/governor gear problem? Don't know where to look next, so anyone that may have had similar problem could chime in?
thanks
thanks
