I have a 1947 8N, front mount distributor, 6 volt system with the positive ground. I recently did a complete tune up including a new voltage regulator. Prior to tuneup, the charging system kept overcharging the battery. Water and acid continually overflows. After tuneup, it still overcharges.
Somewhere in the back of my mind, I remember that you use to do something with the voltage regulator when installing a new one. For the life of me, I can not find any reference to this procedure now. It seems like at one time the new voltage regulator were sold with an instruction sheet.
I checked the voltage output off the generator and it is only 5.1 volts. When I check the manuals all it talks about is replacing the voltage regulator but this does not help.
Any help in stopping this overcharging?
