8n parts...which one ?????
yukon73
I have a 1952 side mount 8n...Found a complete set of trans gears and a hydrolic pump for it...the problem is I can only afford one at this time, which one should I get only a 3 or 4 dollar difference ?????? Thanks
(quoted from post at 02:12:26 01/12/15) I have a 1952 side mount 8n...Found a complete set of trans gears and a hydrolic pump for it...the problem is I can only afford one at this time, which one should I get only a 3 or 4 dollar difference ?????? Thanks
I would get both, but if you can only get one, I would get the pump.
(quoted from post at 14:12:26 01/11/15) I have a 1952 side mount 8n...Found a complete set of trans gears and a hydrolic pump for it...the problem is I can only afford one at this time, which one should I get only a 3 or 4 dollar difference ?????? Thanks
buy both
if/when you break a gear or pump and your tractor is sitting there unusable....
you'll find at [b:99e26346c6]that[/b:99e26346c6] time the part you [b:99e26346c6]have[/b:99e26346c6] to have will cost considerably more than $30 if you can find one at all.
pssst...he'll take $50 for the both of them.
And if you absolutely don't have the cash...sigh, I know that feeling...buy the pump.
N trannys are pretty tough...pumps usually fail first.
(quoted from post at 09:20:28 01/13/15)
buy both
you'll find at [b:43d3bbc4fd]that[/b:43d3bbc4fd] time the part you [b:43d3bbc4fd]have[/b:43d3bbc4fd] to have will cost considerably more than $30 if you can find one at all.
What year did they change the size of the reverse gear ? A 52 should have the big gear but I assume the smaller gear would work if you swapped the whole set ? I don't know what year the parts tractor is ?
