Okay......As suggested, I have changed the spark plugs and it is running worse now than it was before. I have sprayed out the carb with cleaner and it is getting good flow. The points and condenser are new and clean. The points are gapped to the recommended. .025.
It goes down the hill fine but when I get to the bottom and turn to come back up, it almost completely dies. Then it seems to come back and about half way up it almost dies again and runs extremely rough in the process.
I did notice that you can twist the rotor button some and there seems to be wear on the tabs in the distributor cap and the button is scored. The button clip seems loose as well. Could this be the issue?
