I"m having a charging problem with my 8n. I"m under the impression that I should be able to disconnect the battery while the tractor is running and it should continue to run. If this is incorrect I have no problem.
When the tractor is not running battery reads 6 volts. Battery terminal on voltage regulator is showing 6v. Fld and Atm terminals on voltage regulator read 0v.
When it is running all the terminals on the voltage regulater read 0. And across the battery terminals I get 0 volts. I can"t get a
It seems odd that I am getting a 0 volt reading across the battery when it is running.
When I got from the starter back to the ground I"m getting 1.13v.
I know I have a problem just not sure where to start.
Thanks,
Jason
Thanks,
Jason
