(quoted from post at 03:49:35 02/12/12) some info here:
http://www.crossoil.com/xtreme_tractor_fluids.php
more here:
http://www.crossoil.com/lib/docs/packaging_msds/TRACTOR_HYDRAULIC.pdf
It's for sure an economy utf fluid.. however, still likely much better than what was available from 39-52
it states it was tested on a ford tw25, plus a jd tractor.. etc.. etc. listed as for use in warmer climates.. tells me a lil about it's cold pour point..
they make an ultra that is better, listing event he 134d spec..e tc.
http://www.oilmart.com/data/lubricants/pds/47/Xtreme%20Ultra%20TH%20Fluid.pdf
it should be ok. it's not a premium fluid.. but it's better than a poke with a sharp stick.
soundguy
(quoted from post at 01:10:22 02/12/12) Does not meet 134D spec walk away and be safe unless you want to throw your $$ away
(quoted from post at 22:13:50 02/11/12) Has anyone tried the yellow pail of oil from TSC...brand name is Extreme and it is for sump, lift, and gears. I bought two pails tonight since i got each for $26.
