i have an early 8n with front mount dist, upgraded to 12volt. I have had it for 3yrs used to mow 6 acres and blade driveway. It has lost power and trying to determine if it needs a complete rebuild or rings. or to buy another one and keep it for parts.
compression test
front of tractor to back
first kick 60 on all 4
max it would get to 70, 75, 85, 80
with oil added 60 , 90, 95, 90
thay all got better with oil except the first one dropped. they tractor was slightly warm when test was done since i moved it to the heated garage from the barn. Also it has fouled plugs some in the past and uses a qt every 2 hrs.
thanks for the relpies in advance
compression test
