mrjim
Drained the gas tank and surprisingly looks pretty clean inside, what I can see shining a light in there (tank is only about 5 years old). Getting ready to reinstall the sediment bowl in the tank. Do I need any kind of sealant on the threads where it goes in the tank? If so, any recommendations for brand and type? I have a new gasket and filter screen to install with it. Thanks
mrjim.......what Bruce sez....and...pay attention to how the turn-off wheel finally locates. Gotta be able to gitt too itt.......Dell
Do you use it at all your gas joints? IE: such as elbow screen where it goes in the carb? or the gas line where it connects to the sediment bowl and the carb? Thanks
(quoted from post at 08:30:52 09/21/17) Do you use it at all your gas joints? IE: such as elbow screen where it goes in the carb? or the gas line where it connects to the sediment bowl and the carb? Thanks
do not use it on the gas lines it has flared sealing ends. i havenever needed anything on the brass elbow.
