Dbelew
What size wire should go from the starter button to the little terminal on the solenoid? Is bigger better? After I reworded the 8n and tried to start it, the first time it cranked right up. Second time the starter got stuck and would not disengage. Today it tried to crank but I noticed the solenoid smoking from the little terminal in the back. I changed the wire on the push button as it looked like it had some issues. I had a hard time getting the little terminal tight with just the crescent wrench but it is hard to get anything in the tight space. My guess is a loose connection? Wire got hot and solenoid was smoking from the connection.
Sounds like you found the problem with the continuous running starter. If the solenoid was smoking then that wire was shorted to ground somewhere. But to answer your question I would think 14 gauge would be fine. It's only job is to actuate the solenoid.
If you have the correct solenoid with one small terminal close to the block with the wire going to the push
button/safety switch on the shift cover, there should not be any voltage in the wire. It is a grounding
circuit that the push button/safety switch grounds the terminal when pushed.
I just read your other post. If the aftermarket push button switch is hooked to voltage it won't work with a grounding terminal on the solenoid. Solution is to ground one side of the push button.
Remember operating without the neutral start switch is DANGEROUS.
(quoted from post at 18:50:11 05/02/21) If you have the correct solenoid with one small terminal close to the block with the wire going to the push
as battery voltage on it until button is pushed to ground it, then zero.
