I have followed several threads about an 8N overheating. I have had the radiator bored and cleaned, keep radiator full just to top of coils, not above, run 50/50 mixture of water and antifreeze. Water pump appears to be working fine. I can see flow when I remove the radiator cap. thermostat is working fine as far as I can tell. Ran it without thermostat and made no difference. It does not run hot at all up to about half throttle. I can use my bush hog in first gear, at half throttle, all day and it won't overheat. Run the speed up a little bit, and within 2 minutes I have steam coming out of the radiator cap. What am I missing?
