8n Serial #2 value
I just acquired a Ford 8n with the serial #2. It works and runs great but has not been restored. Can anyone give me an estimate of its value? I don't have much experience with tractors and don't know what to list if for if I decide to sell it.
Hi,
Are you sure it is #2. What is the exact serial number including symbols? The standard was a star or diamond followed by 8N x followed by a star or diamond. The x represents the serial number.
One problem in low numbers is haveing the buyer buy into it. If there is any indication at all of a ground out original number, the buyer should back out.
Of interest, the same engines were used on a lot of other machinery and an 8N can have a wierd numbered engine (I have one from what I think was an irrigation pump. There was an attempt to grind off the original number and a poorly executed attempt to stamp an 8N serial number.)
If it is a true very low number, I guess I personally would pay an additional $500 for bragging rights under 1000 and perhaps $900 for bragging rights under 100. Who knows what some other crazy person will pay? Hope this helps.
im the condition described, between 1000 and 1500, the apeal of the ford n tractor is its simplicity, and usability, not its rareity there everywhere, so much so that nearly every single part is reproduced for them, for low serial numbers/ high prices, ya need to play with jd tractors, fords are just good reliable using tractors [ unless you got one with a funk v-8 in it ]
One Million dollars.. :D dunno but would have some some folks stop and look for sure,,,
Ok, thanks for the info. I was planning on using it around the house for a little while then selling it, but after looking around this site I think I might start putting a little work into it and make it a project to restore it. I am kind of new to tractors so this might be a good place to start for me. I'll probably have more questions soon. Thanks.
sounds like a good idea brian, you'll havea lot of fun doing it [even if you develop some language skills at the same time lol] parts are plentiful and right here on this page, upper left corner under 'tractor parts' the small ford n will also do more work than you think it will too, would recomend ordering a manuel before you start it is well worth the cost, [ upper left corner under manuels]
Be careful....they can get addictive!
If it really is s/n 2 AND the rest of the cast numbers match, some of us would be willing to pay a few dollars more for it; $500 to $1000 would be my limit as well.
You can tell what year the engine is by the serial number. It's on the left side of the block, below the head & behind the oil filter canister. If the serial number & casting codes on other parts match (or are close) then the entire tractor is probably the same year as the engine.
But, the engine serial number is only part of the tractor. That could be engine s/n 2 in a later model N.
Check out John Smith's ID page. First, make sure it really is s/n 2. Then, check the casting codes to see if the rest of the tractor matches.
The block casting code in the picture is January (A) 3rd (3) 1950 (0).
Post back & let us know what you find out!
John Smiths ID page
You should change your name to Brian Paydirt.
As I'm sure that SN is worth Something.
Ask awhtx - frequent contributer to this and also the Ford Board - if his early 801 tractor has sparked any interest.
He's the owner of #002
Or as he calls it "Double naught Duece."
I would also ask your question on the Other N tractor site. Those guys over there are somewhat more interested in oddball Ns and may give you more insight or at least a second opinion.
I would do a little learning about all the casting codes cast into the various parts of your tractor to insure your engine was not just transplanted into another chassis.
For reasons that would take a whole page to explain I can not post a link to "the other site"
But you can type it in to your browser from the picture below.
