NOT sure what you mean by "better than the other"?
The Sherman is an auxiliary transmission giving 2 or three extra ranges in each gear of the main transmission.
Several other mfg's offered similar transmissions, as well.
Check out the info on John Smith's site.
Smiths most excellant Ford resource
Bob don't you mean giving it one or 2 extra ranges?? If it is the step up or step down then you have the extra range of the step and the normal gears and if a combo you have 2 extra ranges and the normal gears????
A Sherman does not make 1 n ford better than another. If you look at the n ford part of this you will see all the non starting, non stopping problems people have with them. I started running n fords in 1961. Back then they had the same starting and stopping problems they have today. If I were you I would look for a late 2000 or 3000 ford. They are a far better tractor than the n series.
The sherman trans is in addition to the main trans so yes better, will also add more value to the tractor. here is some data on the sherman combo. For a better understanding of which sherman trans it might be go to my youtube page to identify the different shifting handles. Hit the link. with more questions about the sherman and ford you might be better to post in the ford 9n/2n/8n section next time.
<a href="https://imgur.com/ljmbgGd">
</a>
sherman youtube link
