jacko981
I bought a replacement radiator and ordered an aftermarket shroud with it. After alot of trimming on the outside of the shroud it still looks like the fan could hit it if the front axle swivels. Has anyone tried a smaller fan with a shroud or trimming the existing fan? Thanks
I don't know if I would trim the fan
blades, this could cause it to get out
of balance and wobble and might destroy
water pump prematurely, I would keep
trimming away at the shroud.
(quoted from post at 18:09:26 07/06/17) I don't know if I would trim the fan
hat is what they need, trim, bend, even heat & bend sometimes. Pitiful fitting things!
If you have ever been around flathead v8's very long. You learn to cut the shroud in half
Top and bottom half. Easier to install and adjust so it dont hit fan.. You can get it close so it dont look like it's cut.
I use to have several original Shrouds and sold them then I had none. I needed to install a aftermarket shroud and it did not fit so took one off a parts tractor to use as a pattern to compare the aftermarket shroud too. I keep the original its not for sale I use it as a pattern so I can make the aftermarket shrouds fit... Its a P.I.T.A. job to make a aftermarket shroud fit then add in a replacement radiator I feel you pain.
"it still looks like the fan could hit it if the front axle swivels"
I'm not following. How would that happen?
Aftermarket parts can be a pain sometimes, that's for sure.
I agree with grayrider, in that I would not trim the fan.
You might have to buy a replacement one of those then!
I ended up taking the shroud off and just putting the tractor back together. A friend that was helping me suggested cutting it into a right and left half and mounting that way.
"I thought i read in a post somewhere that when the front axle swivled it could force the shroud into the fan"
I have also heard that if the stops or the front pin were worn, the
axle will hit the distributor cap on a front mount distributor.
That, I have experienced for myself, actually.
I have my '52 in the garage right now and it has the axles set one
bolt hole from all the way in. So looking at it, I can see how it might
be possible to hit the shroud. I jacked it up, weighted the left
side of the front axle and this is as close as I could come to
getting it to hit the shroud. Hard to tell, but the right front tire
is almost a foot off the ground in the picture.
I'm guessing it could with worn out front end parts though.
Inquiring minds... ;)
My 49 8N didn't have a shroud on it when I bought it in 1983. The only time it ever got hot I was shredding tall weeds and plugged the front.
The purpose of the fan shroud is to direct air through the radiator core when the tractor is stationary, as in operating a belt pulley and a buzz saw. You won't see much difference with or without a shroud when the tractor is moving.
75 Tips
How would you know you are safely operating it if it did not have a temp gauge to monitor the temp.
Operating with no shroud you are living on the ragged edge.. If folks are gonna go there I highly recommend a temp gauge be installed... You then can monitor the temp and adjust operation of the tractor to accommodate for the lack of air flow.
Coolant absorbs the heat air takes it away. You can not displace the heat with out good air flow its the law...
That just touches whats needed to keep the engine at a optimal operation temp under all conditions. The number 1 & 2 thangs are proper coolant level and proper air flow. I would not assume because I read it on the internet a shroud is not needed no matter how smart I thought the poster was..
I worked on a 96 ford f150 with a inline 6 today that did not have a shroud. WTF it did not come with one new just a top guard over the fan. I then looked up to see if it had AC it did not. Its rare to see a vehicle with out one so rare I can not recall the ones that did'N have one.
My speculation is AC equipped vehicles brought on the demand for a shroud were its mandatory to keep the ac head pressures in check.
Its worth the effort to have one unless you are stuck with a P.O.S. front mount dist in that case I would ditch the shroud and every thing else thats connected to it :lol:
hey, Hobo, u can have my $62 shroud if you promise to stick that after market pos where the sun dont shine! :x
