First. Thank you in advance.
Questions:
What is acceptable rotational play? I have a video below.
Are there any Deadman switches or other places to look for shorts?
I'm a younger guy. Points and gaps seem easy to set, but maybe I'm wrong. I'm working on an 8n tractor with side mount distributor. Hopefully my terminology is right. I'm working on a 6v system..For reference the sn is 8n460385.
I have spark from the coil to the top of the distributor. Nothing to plugs. I think the rotor play may be way off. I have replaced the Ignitor. I replaced rotor. I replaced the cap. I replaced the points. New condenser. I gapped the points by rotating to the top of the lobe. Then using 025 feeler. The rotor seems like there's a lot of play
youtube.com/shorts/eqD0-JftVkg?feature=share
I'm at a loss. I feel like it is grounding out only because the negative lug on the distributor is hot. I do not get any spark out of any of the caps. If I rotate flywheel to 0 it seems to point at 1.
Back end story, unit started up, after about 30 seconds, it quit. First thought was fuel. Then I pulled spark plugs and there was no spark. Last time points were done was in 2002 along with coil and condenser. This is why I thought the points, coil, and condenser.
Thank you very much. Hard to find good information.
Questions:
