8n spark help please
Ok so I tested I have no power to the coil or distributor I also have
power to one side of the terminal block with the key on and off this
has been converted to 12 volt and yes all of the wires are the right
way
" I also have power to one side of the terminal block with the key on and off "
The purpose of the ignition switch is to connect one side of that terminal block to the other. If you do not get battery voltage on the coil side of the terminal block, jump the ignition switch. If that gets battery voltage to the coil, you found the problem.
75 Tips
