gears
Hi everyone, been reading all the old threads/posts I can find on fixing the 8N rear hubs. I have my friend's over here and both hubs are loose. It appears they both have the double nut, no G clip and one might be welded to the shaft - literally.
Read a lot of great posts (JMOR / HOBO) about putting it together but unsure of the teardown re: split nuts.
My question is how do I release the double nut to remove it? I read where torquing with only 1 on the shaft can cause them to crack/split. I am assuming the same will happen trying to loosen them?
I presume I need to remove that little key...
