My next door neighbor thought there was something
wrong with his tractor. Push on the starter and
nothing. So I go over, and same thing. But when
you hit the starter in makes a faint
Whine or moan noise. The starter is new. I also
noticed that smoke came from the ground wire at
the ground point on the frame.
This tractor was running fine before, but he installed a new battery and says it is negative ground ( so he connected EG post to ground)
Anyway, so I
filed and sanded the connections at the ground, on
the relay and everywhere I could find a connection.
Nothing changed. No starter activity at all, but now
the right hand connection where the ignition wire
goes smokes instead of the ground. It is converted
to 12v and has the NEG post running to ground. Is
that the problem?
Thanks in advance
Anyway, so I
that the problem?
Thanks in advance
