8N starter button
T144
Can anyone explain how the original grounded starter button assembly be used in a 12 volt converted system?
(quoted from post at 22:11:30 11/13/09) Can anyone explain how the original grounded starter button assembly be used in a 12 volt converted system?
Exactly the same as in a 6v system, unless you pulled some shirt of changing the solenoid.
T144.......the same way in the original 6-volt system. The tranny mounted safety starter button don't care 6-or-12v; just like the 3-terminal starter solenoid don't care, 6-or-12v; just like the 6-volt starter motor don't care, positive or negative ground, it just turns faster with 12-volts. ......Dell, a 12v advocate for the right reasons
Thanks Dell,
My starter solenoid has one post for a wire to connect to from a switch. When I bought the tractor, it was wired to a spring loaded toggle switch that directs a positive current to the starter solenoid post. The transmission mounted starter switch was bad and I have since replaced it. When I disconnect the positively charged wiring set up and connect it to the new starter button, nothing happens. Am I missing something?
(quoted from post at 09:04:53 11/14/09) Thanks Dell,
It sounds like you are going to have to get the right solenoid for the tractor, on the correct one, the small post will be hot, and grounding it will activate the solenoid.
They may look the same, but be wired different internally.
Starter Solenoid - 6 Volt - For 8N, 1948-1952. Starter Solenoid, 6 Volt. (Part No: 8N11450) $8.98
http://www.ytmag.com/cgi-bin/store/...p;md=8N&cat=Electrical System&r=mcats
It doesn't matter that it says 6v, even for a 12v, positive, or negative ground.
Make sure you have the correct solenoid. This one from YT says 6 volts, but it works just as well on 12 volts. Small mounting post faces the block.
T144........like I said and Cooke has pictured, the ORIGINAL 6-volt starter solenoid was 3-terminals. Many original starter solenoids have been INCORRECTLY replaced with 4-terminal automotive type solenoids that require you to supply VOLTS from an external switch such as yer spring loaded toggle switch. The ORIGINAL 3-terminal solenoid is INTERNALLY HOT and therefore you ground the little middle terminal (facing the block) with yer tranny shifter safety BIG thumb button. ......Dell
