Mike Gilchrist
I went to start the 49 8N the other day. Solenoid clicks, bendix does not engage. Direct connect with wheeled charger just makes motor hum.
Ordered a new on. Removed old (of course the case came apart.) The hole the starter drive goes into has the goose egg shape so positioning the new one seemed fairly trivial. It was. Bolted down, hooked up wires.
Same thing. Direct connect, it just hums. Take it back out. It spins fine on the bench. Look here and find friendly advice on tilting, getting starter drive behind flywheel. Put it back in and bolt it down. Same thing.
Take it out. Measure the distance from the mounting face on the block to the ring gear -- about an inch.
Measure distance from body of starter to starter gear - more than an inch.
We hooked a chain to the tractor and to my Jeep and rocked it while I looked at the ring gear. It turns, so the engine doesn't appear to be siezed up.
OK gurus, what am I doing wrong? It is a new style starter, and doesn't have the spring and spacers like the OEM model. Otherwise critical measurements appear to be the same.
Shouldn't the gear and bendix be farther back, (more fully extended on starter shaft) behind the flywheel? Am I somehow putting it in partially meshed and it's binding?
To top it off, I am preparing for snow, and just had my machinist put a front loader on it I bought from a neighbor - live hydaulics and done right. The blade is also on the back and weights are installed. Soooo, it is almost impossible to "pull start" because of course both the bucket and blade are down.
Help!
Kind Rgerds,
Mike
Help!
Kind Rgerds,
Mike
