8n Starter Rebuild
Starter rebuild 1951 8n......I am a Firsttimer, looking for help rebuilding starter
Is there an Instructional video or picture illustration showing how to put brushes in and just overall how to ?
Any help will be greatly appreciated....Walter
Two are connected to housing with screws & two require a big heavy soldering iron/copper to solder brush leads to field coil terminals. Otherwise it is disassemble/assemble.
Walt........I use wooden tooth picks to hold the brushes up outta the way when installing the armature back into the case. I assume you turned the commutator and scrapped the mica insulator with broken end of hacksaw blade. Dell
