8N Starter Switch
I want to replace the transmission cover mounted starter switch/button on my tractor.
From looking at Fig. 15 "Transmission Cover, Disassembled" on page 65 of the service manual for the 8N, it looks like I can"t just unscrew the old button and screw in a new one. Do I have to lift the transmission cover and disassemble the whole thing and reassemble it after installing the switch?
I"d appreciate any help you can provide.
Jack O"Rourke
760 240-2178, or 760 220-1738
Serial Number List for Ford: Model 8N
You will have to remove the transmission cover and then wrestle with the switch. It will help to have a couple of wrenches. Also, when you pull the cover watch for a spring to pop up. it is covered by the lip on the back of the transmission cover. It might fall into the transmission, if so you will need a new one. They are cheap and relatively easy to find. The last problem you will face is replacing the three screws near the steering column. It is doable, but you need to have patience and a good wrench.
