8N Starter Won't Engage
My '49 8N starter won't engage. The solenoid clicks, and after repeated attempts, the wires begin to overheat. I tried the old 'jump at the solenoid' but did not work. I then replaced the solenoid, but same result. Is the starter bad, or something simpler, like the ignition switch?
Steve.......you ask....."something simpler, like the ignition switch?"......the ignition switch has 'nuttin' to do with the starter motor or solenoid; just yer ignition coil. Simpler, eh?
It aint'chur solenoid, 'cuz it clicks. From yer description, you have a stuck starter Bendix drive in yer flywheel gear. Just loosen yer 8"-screws and wiggle yer starter motor and yer Bendix gear should retract 'cuz it is nolonger binding. Retighten yer 8"-screws. And think about replacing yer BAD Bendix with a NEW CLUTCH type starter drive.
Why does it amaze you that yer stuck starter motor is overheating yer heavy 1/0 (thick as yer thumb) starter cables??? .......Dell
Steve.......would you believe our host, Yesterdays Tractors, sells them??? $40 (cheap) remember, ALL starter drives must be squeeky clean. and DO NOT play with yer drive extending it. They gitt stuck, and you haffta disassemble it, not fun. ......Dell
Thanks again, Dell - well, I really screwed up now - I loosened the starter bolts and tried to wiggle it, to see if it would unfreeze. But I apparently pulled it out too far, and the end plate popped off, allowing the brushes to free, and now I am not able to get anything back on. Is there a dummy solution to that, other than buying a whole new starter?
Part Two: OK, guys, I priced a new starter today at my local Tractor Supply. My next question is, the new starter already has the new drive. So how do I get the *old* drive out? (looks like I must pry off the round plate at the engine housing - is it that simple? - will it have to be pressed back or just re-sealed?)
Steve,
Unless your starter is kaput, I would not buy a new starter. At most, I suggest you find a quality starter shop in your area, ask two or three or four shops, and give them the starter to look over and renew parts as necessary. Even still, you can put that starter back together with some research in the archives, the manual, and advice from these fellows. As for the bendix, buy the part as a stand alone and put it on yourself, or if you take it to a starter house, let them put it on. Getting it off the flywheel should be a wiggle waggle job. You might need to take off the block drain and the oil filter, but they come off and on easily. If you don't have an oval shaped hole on the starter/flywheel hole then you will have some fun getting it in.
Finally, I suggest you take a buffer or some course sandpaper and shine up the exposed metal. That is where your tractor grounds and it should help your starter spin a bit faster.
Steve.......little late, but you can re-install the brushes yer self. leave the 8"-screws inplace. Just remove the band-clamp and kinda lift the curly spring up and to the side of the brush bracket then juggle the brushes back into the brackets and then yer end will fit and you can re-screw yer 8"-screws. You may find it eazier to completely remove yer starter motor and do it on the work bench.
While yer starter motor is kinda out, wire-brush the gap, both the endplate and the tranny hole and yer starter motor will zing on 6-volts.
Did releasing the starter motor 8"-screws un-stick yer starter Bendix drive??? ......Dell
Thanks again, Dell - at this point, I will replace the whole starter, IF I can get it out!
The armature end of the starter and bendix/drive are still stuck in the bell housing. I pried & tapped a little on the end plate, can get maybe a 1/8" gap but that's it. Any ideas?
Steve
OK, well with the help of my #1 Son, we got the rest of the starter out, got it put back together and put back in, and best part - worked like a charm! So I'm back in biz again (for now). Thanks for all the help, guys!
