8n steering sector wear
I am rebuilding my steering box on a 1948 8n. Is there anyway to tell how much wear on the steering sector gear are acceptable or how to check it? If I take pix of the sectors showing the gear portions, can someone tell by that? I would hate to re-assemble the box if the sectors are worn too much, but sectors are expensive to replace too.
Dennis - the steering sectors for your 1948 8N are not replaceable - they are NLA. You can still get steering sectors for the later 1950-1952 versions though. If the sectors are too worn, the only option is to replace with "decent" early model used sectors, or replace the entire steering box with a later model (some adjustments and dash trimming required).
In my experience when I did a full rebuild on my 1948 8N steering box - replacing the bushings will go a LONG way towards reducing backlash in your steering assembly.
HTH,
Dan
Thanks Dan. By bushings I assume you are talking about the bushings that go in the steering sectors. I was considering just purchasing the whole rebuild kit which includes the bushings, bearings, seals, etc.
The bushings go into the steering sector housing (round housing held onto the side of the steering box). They will need to be reemed a tad to fit. I used a brake hone and it worked fine.
Dan
Dan: I tried to remove the old bushings and ran into trouble. Is there a trick to removing the old bushings? And how about putting in the new ones?
