I have a 1948 8N, 12 volt front distributer. It ran ok, but as I have just recently purchased it I did a few tune-up things to it and now it runs, but only for 5 to 15 minutes and then stops. It stops really quick too, not like it's slowly running out of gas or something. After it sits for 5-10 minutes it will re-start, sometimes it needs to be choked and sometimes it doesn't.
What I did for the tune-up:
- drained and replaced engine and hydraulic oils
- replaced inline fuel filter
- installed a new air breather hose (was non-existent)
- flushed radiator and installed 160* tstat (was non-existent)
- I did nothing with the spark plugs, distrubuter, etc. because that was recently done by the previous owner
I am leaning towards this being a fuel supply issue for 2 reasons:
1. The new inline fuel filter is clear and I can only see a small amount of gas in it- should this be full or am I wrong? (I do have it installed in the proper direction).
2. When the tractor stops I have removed the plug from the bottom of the carb and either get nothing or just a few drips. Definintly not a steady flow though.
I am a beginner at this and am wondering if anyone has any suggestions as to what this could be. Like I said, I am leaning towards fuel related, but I guess I can't rule out electrical either, the wiring is sketchy at best. Thanks for the help!
