What is the purpose of the terminal block?
Based on advice from replies to my last post I took the alternator to a parts store and had it tested. It was fried.
Hooked it up to the existing wiring also adding a 5W side marker light in-line with wire #1. The light burns brightly when the switch is first turned on and under ~500 RPM. However, the light never goes completely out. Didn't notice till late evening yesterday.
Checked all of the wiring to JMOR's diagrams and discovered that there is not a terminal block. Looks like the PO was using the ammeter instead.
What does the block do? Is it needed (know Ford didn't add non-needed parts)? Is it a specific part, do people use something other than 8NN 14448?
Thanks, Don
Thanks, Don
