8n tune up dilemma
DPM NY
Hello, While giving the 8n a tune up, the copper strap in the distributor finally broke off. Question is, can that be repaired/replaced, or is there an insulator that isolates it from the condenser? Thanks, Dave
(quoted from post at 03:31:40 04/15/19) Hello, While giving the 8n a tune up, the copper strap in the distributor finally broke off. Question is, can that be repaired/replaced, or is there an insulator that isolates it from the condenser? Thanks, Dave
Couple ways to fix that. Easy one is to use solid copper wire. Or you can use the copper strip from an old set of points to make a new one, hard part is putting a hole in both ends.
Thanks for the reply, Nicely done. I can fashion something like that, but will need to insulate it from the plate. The reason I ask is it looks like there is nothing to isolate the copper strip and the condenser wire from the body of the distributor plate. Thanks again, Dave
(quoted from post at 04:15:07 04/15/19) Thanks for the reply, Nicely done. I can fashion something like that, but will need to insulate it from the plate. The reason I ask is it looks like there is nothing to isolate the copper strip and the condenser wire from the body of the distributor plate. Thanks again, Dave
You can get those little 1/4" square white plastic insulators I used from NAPA.
(quoted from post at 11:31:40 04/15/19) Hello, While giving the 8n a tune up, the copper strap in the distributor finally broke off. Question is, can that be repaired/replaced, or is there an insulator that isolates it from the condenser? Thanks, Dave
Not sure how the thing was running and not grounding out.
