8n voltage reg
(quoted from post at 14:19:57 02/24/10) i,m installing a 8 volt battery and a new voltage reg need to know how to set the polarity on the new reg
You don't set polarity on a regulator. Rather, you polarize the generator to match the battery polarity as installed (see attached, yours is (a) on left). Next, and just as importantly, a 6 volt regulator regulates the generator output to a voltage too low to keep an 8volt battery properly charged. So don't expect great results.
If you are asking how to polarize the generator, JMOR answered your question. But, if you are trying to charge an 8v battery w/ a 6v generator, you're not going to be very happy.
That 8v battery is no better than the 6v battery that is supposed to be there. A 6v battery needs 7.4v to charge. That's what the v/r is set to do. An 8v battery needs about 9.6v. And, if what you meant to ask was how to adjust the v/r to increase the charge rate, tweaking a v/r isn't all that hard as long as you are prepared for the consequences of failure: a boiled battery, burned up v/r or no charge at all.
I'd clean all the grounds, replace the battery cables & either convert it to 12v or get it back to 6v. That 8v battery is not going to do much for the longevity of your points & lights &, if it's a frontmount, probably your coil as well.
50 Tips
I have followed this forum for a couple of years now and learned a lot from it. One thing I did that is not recommeneded by the fellows with way more knowledge than I, is to put a 9 volt battery in my 9n....It was the BEST thing I ever did to it. It is a front mount 6 volt system and since I put it in, the tractor has started much better and I have not had a lick of trouble with it. I have had it in for 3 years now with no trouble what so ever. Every spring I charge it on the 2 amp setting with my 12 volt smart charger for about an hour or so. ( I charge it in the spring as I live in Northern Manitoba, Canada and I leave the battery outside in the tractor all winter). I use the tractor during the summer and have no issues with the battery, or the rest of the electrical. If/when this battery needs replacing I will be putting another 9v in.
(quoted from post at 16:56:23 02/24/10) I have followed this forum for a couple of years now and learned a lot from it. One thing I did that is not recommeneded by the fellows with way more knowledge than I, is to put a 9 volt battery in my 9n....It was the BEST thing I ever did to it. It is a front mount 6 volt system and since I put it in, the tractor has started much better and I have not had a lick of trouble with it. I have had it in for 3 years now with no trouble what so ever. Every spring I charge it on the 2 amp setting with my 12 volt smart charger for about an hour or so. ( I charge it in the spring as I live in Northern Manitoba, Canada and I leave the battery outside in the tractor all winter). I use the tractor during the summer and have no issues with the battery, or the rest of the electrical. If/when this battery needs replacing I will be putting another 9v in.
Like this?
On a more serious note, on a 9N the 3 brush gen is capable of reaching much higher voltage output than the 8N regulated generator. So, I am not surprised at your success even though it will stress the generator fields a bit.
There is a considerable difference between the charging system on a 9N & an 8N. The initial question here involved an 8v battery in an 8N. The key difference between the two systems is that an 8N has a v/r & the 9N doesn't.
Those 9v batteries are kinda rare. Can you post a picture of it?
