8n will not keep running
j.grif
tractor will start but stops running in a few seconds. checked filters,shut off valve,new coil and condenser,runs for a time at full throttle only but reduce power slightly and 8n shuts down.Seems to have decent spark. a mystery. One thing is when it does start for a short time the amp gage pegs to the right even with fully charged battery. Have been told thats normal at times????
griffy.......a few seconds of run time is usually a BAD condenser right outta the box. Buy yer next condenser from a different store. Just a couple of days ago, it was the 4th condenser that worked from a 3rd store.
You report....."runs for a time at full throttle only but reduce power slightly and 8n shuts down"......this is NOT related to weak sparkies caused by BAD condenser, this is usually caused by running on just 2-cylinders. Check yer firing order 1,2,4,3 CCW. Generally sparkies 3&4 are miss-swapped.
You ask......"One thing is when it does start for a short time the amp gage pegs to the right even with fully charged battery. Have been told thats normal at times????"......since you don't specify iff'n yer tractor is OEM 6-volt positive ground or 12-volt converted negative ground. Its hard to guess why yer pegging yer amp-meter. Does it ever stops pegging??? I flunked mind reading, just ask my ex-wife.......Dell, the mindless
(quoted from post at 11:23:30 05/27/09) tractor will start but stops running in a few seconds. checked filters,shut off valve,new coil and condenser,runs for a time at full throttle only but reduce power slightly and 8n shuts down.Seems to have decent spark. a mystery. One thing is when it does start for a short time the amp gage pegs to the right even with fully charged battery. Have been told thats normal at times????
A "few seconds" is awfully short. Not a minute or two? Can you keep it running with choke modulation?
