8N with no power ( update )
RLBII
Ok, Checked the wires and they were good. Checked the point gap and was a little small so I adjusted them. Checked gas flow coming out of the carb, Looked good to me, I dont know how it should be but I would say it was coming out as strong as it is from the gas line. This helped as I was able to plow the drive. I still need the choke pulled out. With the choke out it runs good with no spitting, back firing or dying. Dont have enough power for forth gear. I will get some carb cleaner and soak the carb next. Then the compression and vacuum check. Thanks for all your ideas.
RL:
Fourth gear is a transport gear. Do not expect to use your blade or just about any other tool in fourth gear.
Dean
No, I wasnt trying to do that. I have a front dozer blade on it and it dont move if I was to hit somthing. This is the first time using the blade.
