8N Won't Crank
usafsp12
OK, charged the battery and changed the starter solenoid. The darn tractor just won't turn over when I hit the starter switch. Anybody with any ideas?
(quoted from post at 12:54:51 03/24/19) OK, charged the battery and changed the starter solenoid. The darn tractor just won't turn over when I hit the starter switch. Anybody with any ideas?
[b:1c2da0f051][u:1c2da0f051][color=red:1c2da0f051]Make sure the tractor is in neutral.[/color:1c2da0f051][/u:1c2da0f051] [/b:1c2da0f051]
  • [*:1c2da0f051]Then take a set of jumper cables and jumper the ungrounded battery terminal to the stud on the starter. If the starter does not crank you have a dead battery, bad ground at the battery or starter, or a dead starter.[*:1c2da0f051]If the starter cranks jumper the small stud on the solenoid to ground. If the starter cranks you have a problem in the ground circuit from solenoid to the starter switch or a bad starter switch.[/list:o:1c2da0f051]TOH
