8n won't run
Roger Steele
I have a old 8n that I pulled the hood, replaced the plugs and wires, points, condensor, rotor and cap. I have fire, but it seems to lock up at times when I try to start the engine also it is pushing black looking fuel out the rear exhaust port. Maybe wired wrong? Thanks for your help.
Roger,
I have a 53 jub and I also have the locking up problem along with the black stuff coming outta the exhaust gaskets. Come to find out, I had my #3 and#4 plug wires backwards. Now I aint sure but all that unspent fuel in the nonfiring cylinders was taking the oil film off the cylinder walls making the engine lock up. As for the balck stuff, It was coming from the cylinders that were not firing. Just to pass along advice I've gotten on this site, check your firing order and make sure you have it wired right.
Andy
Am I right in thinking the front of the tractor is #1?
Engine rotation is counterclockwise when looking at the rotor from the front of the engine?
Quoting a relpy from Old, who I think knows his stuff, tells me that 99% inline engines does in fact start from the front of the tractor. He also says ther is a few oddball engines out there that are different. Im not sure about the 8N's.
