8N won't start
ncken
I"m ready to give up!!! Have spent much spare time trying to start my 1952 8N. I"ve rebuilt the carb., checked spark, and put in a new condenser and ignition wires (points ok). Have fire at the plugs. It actually started one time on three cylinders while I was checking the spark on the 4th cylinder. Hasn"t fired since...Winding the starter will eventually load enough fuel to the point it runs out of the intake end.
Any ideas or suggestions would be appreciated.
Change your spark plugs. Use Autolite 437 plugs. You are definitely fouling the plugs if gas is dripping from the intake.
Save your old plugs and burn off the gas with a propane torch. Clean them, set the gap and re-use them next time you foul them.
It is important for you to tell us if your tractor has a 6 volt or 12 volt electrical system. The troubleshooting is different based upon the configuration of your engine.
First, as Dennis said, replace the plugs. You flooded it, the plugs are fouled. It will be it next to impossible to start. You don't need to toss them; heat the tips for a few seconds w/ a propane torch to burn off the invisible spark-robbing deposits from today's additive filled gasoline........or wash them in lacquer thinner.
Next, re-check the point gap (.025) and dress the points by running a piece of card stock or a brown paper bag through them.
The next thing you need to do is isolate the problem to fuel or spark. I know you said you rebuilt the carb & have good spark....well, if it has fuel & spark, it would be running. So, I'm thinking maybe you missed something or didn't check spark & fuel correctly.
There are three very important tools you always need to have in your N tool box: a 3 inch piece of wire w/ alligator clips on each end, an old spark plug w/ the gap opened to at least 3/16” ( ¼” is better) and a 7/16 box end wrench. And, you really do need a working ammeter. With these tools, you can quickly narrow down most N problems to spark or fuel.
First, check for fuel. Remove the bolt in the bottom of the carb; as long as the fuel is turned on, you should see gas flowing out of the carb. If it’s a dribble, or runs for 5 seconds & stops, or none at all, you have solved half the problem: it’s fuel related. If gas flows well out of the carb & only stops when you turn it off at the sediment bowl, chances are very good it’s not a fuel problem. So, next, crank the engine & look at the ammeter. What is the ammeter doing? Does it show a constant discharge, no movement at all, or does it dip? Next, get the old plug, ground it to a rust & paint free spot on the engine, turn the key on & crank the engine. If the spark jumps the 3/16” gap, you probably don’t have a spark problem. If it won’t jump the 3/16” gap, you have a spark problem. If the ammeter shows a constant discharge, or doesn’t move at all, that also tells you that you have a spark problem. Jump the ignition switch w/ your jumper wire & see what happens. If it runs, you found the problem. If it doesn’t have spark after you jump the ignition switch, post back for more info on further troubleshooting.
If it does not have gas coming out of the carb at a steady stream w/ the bolt out, you have a fuel problem. First, remove the gas cap. Your vent could be clogged & it vacuum locked. If that doesn’t work, tap the carb bowl w/ a hammer handle in case the float is sticking closed. (don’t whack it w/ the head of the hammer; you can crack the bowl). If you still don’t see gas flowing, the N has three fuel screens; one in the brass elbow, one in the top of the sediment bowl & one on the stem of the sediment bowl in the gas tank. Check the screen in the elbow & the screen in the top of the sediment bowl. (don’t worry about the one in the tank) Both probably need to be cleaned. If you have the fuel knob turned on all the way, & 1 gallon or less in the tank, it may be trying to feed off of the reserve inlet which is probably clogged. Only open it 2 full turns. Put at least 2 gallons in the tank.
There are ways to check for spark & fuel that work & ways that don't. For example, having gas to the carb is nice, but having it past the float is what counts! That’s why removing the bolt in the bottom of the carb is the way to do it. And, same thing w/ spark at the plugs. Some folks think that checking for spark means pulling a plug wire off & looking for one. Well, it's the distance the spark jumps at the plug that gives you the info you want. It takes about 17kv to jump a 3/16" gap & 22kv to jump ¼” in the open air, so that's why you need to use a spark plug. Or, a store bought plug checker. Remember, it’s 14psi outside of the engine & about 90psi at a 6:1 compression ratio in the cylinders & compressed air crates electrical resistance, so you really need the 17-22kv to fire the plugs when the engine is running. There are other good ways to check for fuel & spark, but these ways work for me.
Lastly, you are using waaaay too much choke & flooding the engine which in turn fouls the plugs. Get a can of starting fluid.
50 Tips
I've resisted trying new plugs since I see spark on the ones I'm using, but so be it. New plugs tomorrow. I'll post you with the results.
thanks
I've read through a lot of topics on this forum, and many have mentioned a firing order of 1,2,3,4.
My '52, with a side mount distributor appears to have a 1,2,4,3 order. Does this sound right?
I've never seen any reference to a 1-2-3-4 firing order. That's the cylinder sequence, radiator to dashboard. If anyone calls that the firing order, they're wrong.
The firing order is indeed 1-2-4-3, CCW.
thanks to all for the advice on the plugs. Finally got them in today. It fired right up.
Used Autolite 437s, although parts book called for 216s.
thanks again.
