9 bolt adapter plates
rcorf
looking for wheel adapters for a late jd b i have cast centers now was wondering if there was an adapter to cconvert my current hubs to 9 bolt thanks
Late JD B's were available from the factory with pressed steel wheels, Dad had a '47 B with presses rims. I believe they used 9 bolt rims. Check if the factory hubs for pressed wheels will work with your wheels. If you are running stock tires (9-38 or similar), you could look for a set of original pressed wheels with hubs.
I have a set of 9 bolt hubs for a B. There is small chunk broke on
one. I think I have the chunk. Will sell, but not sure what they are worth.
