JAC FARMING
I’ve rebuilt the pto all new seals in the clutch new discs new pto brake
Ive rebuilt the dual power new seals in the high clutch pack new discs new sleeve in the housing
New hydraulic pump
My problem is the pto doesn’t shut off with dual power on high till half throttle and only makes 130 psi at idle while with the dp in low it makes 180-190 at idle. I have taken the pto and dual power apart multiple times and i cant find anything wrong. Idk what else there is to check.
New hydraulic pump
