901 ford diesel
I pulled the fuel pump to replace 3 seals that were leaking fuel to the oil pan. My mistake was that I turned the engine without the fuel pump and now I cannot get it going. My problem is how to identify piston #1 at compression stage to set the pump in. I would appreciate any help with this problem.
Thanks in advance.
Pull the valve cover. Turn the engine over with a wrench. When you see #1 intake valve close turn the engine another half a turn till you see the timing mark on the flywheel through the inspection port.
