Is the CEL lit?It goes to 2000 to 2200 RPMs and won't slow down. IAC is new, If IAC is disconnected electrically, it slows down to 600 to 800 RPMs, but wants to stop, but picks up again and continues that hiccuping.
What needs to be checked next? Thanks
He ain't OBD II, so may have to use brains!.....Is the CEL lit?
Have you scanned it for trouble codes?
Where is that located on the engine? And thank youThrottle position sensor?
Should be under the intake below the throttle shaft/linkage (front of the engine right after the rubber air intake pipe enters the cast plenum)Where is that located on the engine? And thank you
Don't know where the CEL is (I'm not "up to speed") on this truck !!!!Is the CEL lit?
Check Engine LightDon't know where the CEL is (I'm not "up to speed") on this truck !!!!
Have not scanned for codes.
5.8 liter EFI engine V8.Check for air leaks and do a vac. test. What is your engine? Little Windser? Thought no F 150 46O's.
The IAC is new.How long ago was the IAC valve replaced?
How did the symptoms come about?
If that one has the map sensor on the fire wall, check the rubber vacuum line running to it.
Some of the older Fords need to sit and run for 15~30 minutes to relearn the idle after disconnecting the battery/jump starting/replacing the IAC etc.
Rectangular black box about 2"x3"x1" with a mounting tab, single vacuum line and 3 wire connector. I've seen them mounted to the firewall and in fenderwellsThe IAC is new.
What does the map sensor look like?
Thank for the note about "relearn the idle".
No sense taking it for a drive through the parts department without looking at possible trouble codes and viewing sensor outputs to see if all are in their expected range.The IAC is new.
No Ford 1991expert but I believe there is an IAC relearn process .It goes to 2000 to 2200 RPMs and won't slow down. IAC is new, If IAC is disconnected electrically, it slows down to 600 to 800 RPMs, but wants to stop, but picks up again and continues that hiccuping.
The trouble codes in OBD1 are limited, but I would still pull them. I have an old scanner with a Ford adapter, not that it helps you.It goes to 2000 to 2200 RPMs and won't slow down. IAC is new, If IAC is disconnected electrically, it slows down to 600 to 800 RPMs, but wants to stop, but picks up again and continues that hiccuping.
is this it see photo It's on a mechanical mount by the A/C. I pulled that line and the RPMs dropped to 1000. That line goes to the intake.Rectangular black box about 2"x3"x1" with a mounting tab, single vacuum line and 3 wire connector. I've seen them mounted to the firewall and in fenderwells
Here is a video showing how to check the codes by shorting the test plug terminals and reading the CEL flashes.The trouble codes in OBD1 are limited, but I would still pull them. I have an old scanner with a Ford adapter, not that it helps you.
Check the TPS with the key on engine off at operating temperature. It should read less than one volt at idle and 5 volts at WOT.
I'd also check the base timing and for vacuum leaks.
