930 Wheatland Drawbar
mndan
I have a Case 930 Wheatland that I am having trouble finding a drawbar, roller and cast iron bracket for. The cast mounting bracket under the tractor cracked and I didn't see it and when I was plowing, I broke the bracket and pulled the whole drawbar right off the tractor! Does anybody know where I could get these parts. Everyone has told me that the Standard, wheatland and row crop versions all have different brackets and drawbar sizes. I do not want a clevis style hitch anymore and would like just a straight style drawbar like on the row crop models. Can I do that on a wheatland model? Any help would be greatly appreciated. I should have come here first! Thanks everyone, Dan
I had a similar problem except my bar got broken off when the roller gave. After taking it apart and seeing the belly section is held by two fairly small bolts we decided to cut the other end of the bar off and get some flat stock to make a drawbar that bolts to the swing bar. The swing bar has about 6 larger bolts attaching it to the tractor so this should work well. I know this isn't ideal if you are doing certain kinds of pulling as your pull point is not the center of the tractor. I guess it just depends on what you want to use it for, but that center hitch bracket seems horribly attached for its purpose.
