95 655d backhoe question.
dannyidp
Hi guys I sold my John Deere and just purchased a 655d Ford that needs a lot of work so it will probably be another restoration project like the 5000 Ford project. My question what's the proper transmission fluid and does it mix with the rear end? I haven't got it home yet so I'm not sure. It's supposed to come with a service manual.
The power steering isn't working due to a hose and the engine is pouring raw diesel smoke but it cranks time you touch it so I'm thinking there's a stuck injector. I don't think the plungers in the pump would do that so I'll keep you guys informed as I go along.
(quoted from post at 00:20:39 06/23/23) Trans and rear use the same oil. Hydra Trans, 134 , Hygard 303. Any trans hydraulic fluids
303 is outdated, and any fluids claiming to be 303 are not, use those at your own risk. JD 303 used sperm whale oil, as a component, which has not been available since about 1974. Hy Gard replaced it. JD J20C is the current spec and is backwards compatible to earlier Hy Gard specs and the John Deere 303 Special Purpose Oil.
